Nitro Gear
Toyota Trucks & Land Cruisers are well known for their strength & reliability all over the world.  Out of the box they feature some pretty great drivetrain, but they do have their limits.   The factory 30 spline full-floater axle shafts are not built to withstand the added stress of larger tires and heavy offroad use. Nitro Gear & Axle has addressed this by offering a range of Heavy Duty Chromoly Rear Full Float Axles.  The only Full Float rearends offered by Toyota in the US were in Dually Pickups, and FZJ80 Land Cruiser, however Full float axles were much more popular worldwide in all models of Landcruisers and are commonly used as an upgrade for US models and otherwise.
Chromoly Full Float Rear Axle Shafts for Toyota Land Cruiser & More:
-Made in USA
-High strength Chromoly Material featuring State of the art machining, heat-treating and polishing processes for uniformity and ultimate in strength.
-Wide application range suiting most Toyota pickups, 4runners & Land Cruisers as well as custom applications
AX TFF-FJ40
TOYOTA F/F CHROMOLY 30 SPL AXLE SHAFTS FITS FJ40 REAR, FULL FLOAT ONLY!
AX TFF-FJ60
TOYOTA F/F CHROMOLY 30 SPL AXLE SHAFTS FITS FJ60/HJ60 /62REAR, FULL FLOAT ONLY!
AX TFF-FJ80
TOYOTA F/F CHROMOLY 30 SPL AXLE SHAFTS FITS FZJ80, HDJ80 REAR, FULL FLOAT ONLY!
AX TFF30-L  &  AX TFF30-R   (CTL)
TOYOTA F/F 30 SPL CTL AXLES ELOCKER OK! ENOUGH SPLINE TO WORK FOR 40, 60, 80 SERIES LC ETC
CTL (Cut-to-length).  This means the axles come with extra-long splines to accommodate numerous applications. -Long splines also allow use of OEM Cable / Electric Locker.  Simply chop to desired length.  This makes them easy to stock for the average 4×4 shop, as 1 pair of shafts fits many applications.
Individual Axles, Rear Axles, Drive Flanges, Knuckle overhaul kits, wheel bearings and more
WWW.NITRO-GEAR.COM   info@nitro-gear.com
Available through:
JTS PARTS & ACCESSORIES    www.justdifferentials.com  509.888.2953   info@justdifferentials.com
Comments
comments
